Why Network Card with Static IP Address Sometimes Can't Bind IP Address?
Network card eth0 of the industry controller IC3173's is set to static IP address. If you use ifconfig to query the network card, sometimes the return information contains IP address, sometimes not. Why? Please help to analyze the causes of the problem, thank you!
Message 1 of 1
(1,830 Views)
