Why Real Time Card OCI 7030/6030 not appears on DAQmx on MAX?
1)-
I have installed real time card PCI 7030/6030. When i opened MAX and went to Devices and interfaces it does not appears on DAQmx ,instead it appears on Traditional DAQ.
2)-
another thing is that When i used to open in LabVIEW 7,
on DaqAssistant  it does not appear to configure for AI channels.
if any idea please help
thankz
Haider +92 345 5 2828 70
(3,729 Views)
It doesn't show up because unfortunately that board is not supported in DAQmx.  It is only supported in Traditional DAQ.
StuartG
(3,723 Views)
thanks
now it is not working with NI daqmx
but in future is it possible in its next versions?
Haider
(3,711 Views)
Unfortunately, we have no plans to support this board in DAQmx.  At this point if you want to use LabVIEW RT with DAQmx your best option is to either buy a PXI controller with an M Series board or to take a desktop machine and use it as an RT machine with a PCI DAQmx card.  If you have questions let me know.
StuartG
(3,704 Views)
Hi Haider,
You might also want to take a look at the 7041/6040E board as this is an equivalent RT/DAQ board that supports DAQmx.
Steven B.
(3,697 Views)
