Why does Self Test fail for Remote System's PCI-6723 (NI-DAQmx 7.3.0)?
My remote PC's hard disk has been formatted using 'PC Format Disk For LabVIEW Real-Time 7.1'.
Using MAX I have downloaded LabVIEW Real-Time 7.1 and NI-DAQmx 7.3.0
The remote PC currently has a PCI-6723 Analog Output card fitted.
IP address etc. has been set up for the remote PC OK, and the PCI-6723 NI-DAQmx device is shown in 'Devices and Interfaces' for the Remote System.
Either runing Self Test for the card, testing a channel created (in NI-DAQmx Global Channels), or running an example RT VI fails.
Running Self test for example gives the error
"The device self test has failed. The error report from the device driver is as follows:
Error -88905 occurred at Self Test
Possible reason(s):
An internal error occured.
(3,170 Views)
Hi Andrew,
I understand you have been speaking with one of my colleagues on this matter and have found the problem to be to do with the third party power supply you were using.
Apparently The ATX power supply works fine but the AT power supply caused problems. Glad you got this solved.
Peter H.
Applications Engineer.
NIUK.
(3,157 Views)
