Why does the memory usage of my cRIO rise up until crash?
So far, all were trying unsuccessfully, unfortunately ...
Now I have endeckt the corner from the disaster is coming!
But what is it I can not say!
Have now photographed all the time loop in which the memory hog sitting.
Additionally, I have the whole VI printed in PDF.
Hope someone has an idea?
Thanks in advance
matze
Message 11 of 16
(2,459 Views)
Hello MaJahn,
what happend if you set the dt fromt the timed loop for ftp transfer from 1 to 20 ms?
I see you have implemented a time 10ms but please rise this to 20ms.
The error handling is not connected thru all functions and vi´s so if you get an error this error will not be reported, like if you read from an empty queue. Please look at the elements in your queues if this rise.
All queues are not limited in size so each queue can rise to an memory overflow. It´s also a little bit better to use the RT FIFO, like in the sent example, for queueing elemts on an RT target.
best regards
Alexander
Message 12 of 16
(2,444 Views)
Thanks for the answer!
So when I changed dt to 20ms nothing changed. (was not expected to be)
Furthermore I controlled the queues for an rise and there were nothing. They were leaving on the same values during the memory expands.
If an queue will cause a memory overflow how can I see this. I just made an Preview of the queue and watched the Element in the monitoring Probe (don't know if this is right?! On German it's "Sondenüberwachungsfenster")
So I don't even have an idea what it could be...
Greez
Matze
Message 13 of 16
(2,430 Views)
Is it Possibile that it is the DMA FiFo itself?!
HELP.... Smiley Sad
MaJahn
Message 14 of 16
(2,419 Views)
Accepted by topic author MaJahn
Hello MaJahn
you can use the get queue status function to look into the queue how many elements are used.
Try to give your queues a maximum size at obtain queue.
Have you tried to implement the errorhandling?
The DMA FIFO read can also be the problem because if your CPU run with 100% the memory will not elected.
Why is My Real-Time CPU at 100% When Reading from a DMA FIFO (FPGA)?
Have you tried to use a while loop instead of timed loop, if then the error happend?
best regards
Alexander
Message 15 of 16
(2,410 Views)
Smiley Very Happy
Thank You...
I Fond It!
It was the orange-green Queue! It wrote with every iteration one Element into it!...
damn am I Happy....
Message 16 of 16
(2,379 Views)
