Why is the error message altered when passed trough a shared variable with real-time FIFO enabled?
See attachment.
This has to be a bug?
I don’t get this behaviour when the shared variable is not enabled as real-time FIFO.
Terje
(4,058 Views)
Hi Terje
I was not able to reproduce this behaviour in LabVIEW 8.5. I made a program that was identical to the one depicted in the last post, and enabled real-time FIFO on the variable. To get any further I probably need some more information about your set-up. Which version of LabVIEW are you using? Could you also post the library that contains the shared variable?
Regards
Øyvind Ø
(4,030 Views)
Hi Øyvind and thank you for your reply
I use LabVIEW 8.5 with the real-time and FPGA module.
I have attached a library which is the same as the example as above. I would really appreciate if you could see if you get the same behaviour as me. This bug had me fooled for hours.
Terje
(4,024 Views)
I managed to reproduce it now. The only thing I did differently was that my shared variable was network-published and not single-processed. I will go ahead and report this to R&D for further investigation.
Regards
Øyvind Ø
(4,012 Views)
