Wireless connection to FieldPoint
I'm going to do a testing at a remote location through Compact FieldPoint (FP). Any idea and suggestion on the wireless connection between FP and monitoring computer or server?
(3,100 Views)
Thank you for contacting National Instruments.
If your computer network will be within 300 feet of your cFP controller, a wireless access point would probably work the best. This will essentially be same as connecting to your ethernet with a cable, but without the cable. There are many different companies that create these wireless network access points, if the range is too great, you may need to look into adding a repeater to extend your range.
Bill B
(3,100 Views)
