Would there be any problem if I use three NI 9233 DAQ with NI 9172 to acquire impact hammer test data?
I am using three NI 9233 DAQ systems with Signal Express Sound and Vibration tool kit to acquire impact hammer test data. I was wondering if this setup would be ok and would initiate triggered data acquisition on all the channels.
(3,716 Views)
Using either the Sound and Vibration Assistant, or LabVIEW, you will be able to set up triggers for pre and post hammer tap acquisition.  What data acquisition software are you using?
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(3,713 Views)
I am planning to use the Sound and Vibration assistant. Also, are there any examples on how to set these triggers. I am student and am using the NI DAQ and software for the first time.
(3,711 Views)
I am right now working with Signal Express v 2.51 and it has the Sound and Vibration assistant in it.
(3,710 Views)
In the Sound and Vibration Assistant, pull down the help menu and select Sound and Vibration Assistant examples.  Select the impact test example.  It uses a hammer and an accel and does the triggering.
Preston Johnson
cbt
512 431 2371
(3,703 Views)
