XPC Target: Speedgoat
Hi all,
Recently, I was asked to see whether LabVIEW (with RT Module, I assume) can communicate and control an XPc Target Box by Speedgoat. The info on this box can be found here:
http://gorealspeed.com/products/machines/classic/datasheet/datasheet.html
I've searched the net but the result was, so far, negative.  However, before I give up, I hope I can get some one to confirm this. If there are tests and things that need to be checked out first to confirm, please let me know.
Thanks!
Shazlan
(6,039 Views)
No, LabVIEW Real-Time does 't support this target.
(6,024 Views)
Interfacing LabView GUI with Simulink Real Time Application deployed in Speedgoat target.
Can we visualize outputs of the Speedgoat target machine by using LabView GUI?
If yes? How to access and visualize using LabView UI ? Any API interface available to interface with Speedgoat target and Simulink Real time application?
(3,995 Views)
