XY real time data aquisition
I'm interfacing a thermoluminescence system .
I should plot the signal of the counter vs the temperature of the thermocouple monitoring a linear ramp from ambient to 470?C, which takes 90 sec, and I must do this in real time.How may I do?
(3,238 Views)
You can acquire the temperature on one of the analog input channels provided you have the appropriate transducer. You can directly plot this data use a waveform graph. What are you using the counter for ?If you want to timestamp the temperature then use it as the x-scale for your plot.
Shiv
(3,238 Views)
