analog voltage measurement with mcc usb-2527 data acquisition board
Hello, I'm new to labview and need to write a VI that measures the real time voltage from a function generator using a mcc usb-2527 data acquisition board. I've been using the mcc data acquisition that was installed under user libraries in a past VI that that converted a signal from digital to analog, but I'm having problems running the opposite. I've attached the VI that I'm working with and am hoping to get it to output a digital function from an analog one and then alter it to display the real time voltage of that function. Any input is very much appreciated. Thanks!
(5,750 Views)
Hello iuv6o7,
You've only uploaded your main VI. All of the subVI's are missing. How do you communicate with the USB-2527? Are these all VISA calls? I didn't find any drivers for the device listed on NI's website.
Jonathan L.
Technical Support Section Manager
(5,728 Views)
You're best bet is to use MCC's email or telephone support, both of which are free.  Go to www.mccdaq.com, and click on the "support" tab for all your support options.  They are good at providing SW support in LV, C and VB.
(5,484 Views)
