asynchronous communication between loops - looing for a suggestion
I have a several loops runnig in parallel, However I want some of them be be "activated"  by other.
Lets say loop A detects a task that has to be executed by loop B.  I want the loop B to wait on hold without using CPU time or delays and to start immediately after loop A  said so. When the task is done loop B waits for another call. In the mean time loop A goes on no matter what. This will be done many times a second  under RT.
I do not want this to be a subroutine, I do not want it to use while do with a delay. What are my best options. I was thinking about event and FIFOs. I appreciate any suggestions.
I am looking for something like the Linux/C select function. thanks
(3,887 Views)
I'm not sure what is available with real time. Would notifiers work?
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,886 Views)
Notifers or queues will work using a basic producer/consumer architecture across multiple VIs.
Take a look at the Asynchronous Message Communication Reference Design and the Queued Message Handler design pattern included there.
http://zone.ni.com/devzone/cda/epd/p/id/6091
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(3,868 Views)
I used notifiers under rt and it works.
I am still loking for a feature like a shared memory  from linux. Anything can write to it and anything can read it, any time. It is a kind of system status - set of variables that describe the current situation.  I would like to be able to have an instant accest to it any time. I am using local variables now - it is within same vi - just independednt loops.
(3,808 Views)
Andy, Maybe and Action engine would suffice? See here
Hope this helps.
(3,804 Views)
