basic real time network communications
Hello
I am trying to get LABVIEW 7 to receive data from a custom application using Ethernet.
I have reviewed the information on http://zone.ni.com/devzone/conceptd.nsf/webmain/A6F17EE4ADCAB99686256D5E0053E210#2
however I have not fingered out how to apply this in practice.
i can modify the custom application in any way that is needed to conform to labviews protocols.
my question is as follows:
what steps must I take to receive data from an application, and have the data (eg. temperatures recorded in real time using custom data acquisition hardware) displayed (and ultimately logged) using labview on a different computer from the other data acquisition.
thank you for your help.
Roger Barchha
(3,463 Views)
the document you linked discribes the use of the LabVIEW RT module to communicate with a LabVIEW RT Controller (PXI-System, Fieldpoint system etc.), so this won´t help you much. You need to search for information about TCP/IP communication. Here you can find some information:
You will find examples for LabView there as well.
Hope this helps!
(3,453 Views)
Ok, thank you for that information, i will review that site, and let you know how it turned out.
again, many thanks.
Roger Barchha
(3,446 Views)
