c-RIO Real-Time clock accuracy
I plan to send an Network Time Protocol (NTP) (not SNTP) message to set the time of RT controller in the c-RIO.  How accurately will the c-RIO this time.  Will it hold it in the milliseconds, microseconds?
I cannot use GPS.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(3,749 Views)
Since the accuracy is listed as 200 ppm (for all conditions; 35 ppm at 25 degrees C), you shouldn't expect to see a drift of more than 200 microseconds per second.  Also, NTP is listed having accuracies of up to 200 microseconds on a local network.  Therefore, the cRIO should have a timing accuracy of around 0.5 ms.
Jared S.
Applications Engineering
(3,676 Views)
