cDAQ-9191 with NI-9219 Module Not Connecting to NI-MAX in Windows 8.1
NI MAX won't find my cDAQ-9191 chassis and corresponding NI-9219 Module on this computer. It will find it on another computer just fine. I just installed the latest cDAQ-9191 firmware (1.5.0f0) and still no joy. I can take the network cable out of this computer and plug it into the other/working computer, and NI MAX picks up the device almost instantly.
What could the issue be? Windows 8.1?
NI-MAX Info is below...
Operating System(OS) Windows 8 Home Edition
OS Version 6.02.9200
OS Info
Processor Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz / Intel64 Family 6 Model 60 Stepping 3 / GenuineIntel / 3398 MHz
Number of Processors 4
Physical Memory 7.87 GB of RAM
Drive C:\ 203 GB of 232 GB free
National Instruments Software: Version:
NI-DAQmx Device Driver 9.9.0f0
NI-DAQmx ADE Support 9.9.0
NI-DAQmx MAX Configuration 9.9.0
NI I/O Trace 3.1.1f0
LabVIEW Run-Time 2012 SP1 f5 12.0.1
Measurement & Automation Explorer 5.6.0f0
Measurement Studio Visual Studio 2010 Support - See individual versions below.
DotNET
Common 13.0.40.190
Common (64-bit) 13.0.40.190
NI PXI Platform Services 4.0.1
NI-PAL Software 3.0.0
NI System Configuration 5.6.0f1
NI-VISA 5.4.1
NI-VISA Runtime 5.4.1
LabVIEW Run-Time 2013 SP1 f2 13.0.1
(5,612 Views)
Just to clarify, are you using Windows 8 or Windows 8.1? With Windows 8, your configuration appears to be compatible. I have included some information and steps below for troubleshooting your wireless chassis.
http://digital.ni.com/public.nsf/allkb/E67B4E4749F378FF862577270059BD4B
I hope this helps!
(5,567 Views)
