cRIO 9024 USB stick not found?
Hey there,
I'm working with cRIO-2024 and i want to save some data do an external usb stick (storage of 1.85 GB) via the usb port.
Stick is formatted to FAT32 and empty.
Tried to write into a new file, my usb stick remains empty.
Also i created a test folder and file to see if i can list them, nothing happens.
 (used u:\, v:\, w:\ and x:\ as path)
So why can't i find my usb stick?
Thanks for your help.
Message 1 of 10
(6,128 Views)
could you post some code you are using, that would help
Message 2 of 10
(6,111 Views)
here the code i'm using.
The Error-Code is 6, generic file I/O error for the path u:\ (both codes).
Message 3 of 10
(6,101 Views)
Hi!
Did you try a simple code like here:
Titel: How to use cRIO USB mass storage? - Discussion Forums - National Instruments
URL: http://forums.ni.com/t5/LabVIEW/How-to-use-cRIO-USB-mass-storage/td-p/460617
Regards!
Message 4 of 10
(6,097 Views)
Sorry, i think we posted at the same time. i didnt see the code
Message 5 of 10
(6,095 Views)
Hi
the cRIO-9024 has a USB 2.0 Port.
Could you try placing a dummy file on the System via FTP and then try again. Also try putting the file in a folder.
Message 6 of 10
(6,089 Views)
To access the data contained on the USB flash drive connected the Compact RIO, open an Internet Explorer browser window from a networked host machine and enter ftp://xx.xx.xx.xx/u:/ in the address bar, where xx.xx.xx.xx is the IP address of the Compact RIO.
Message 7 of 10
(6,080 Views)
Hey,
thanks for the help.
I tried to place a dummy file via ftp to the real time system  and that works.
A file to the usb stick isn't working.
Also i tried to see what i get with internet explorer on the RT system. I see, what i saw previously on the RT, but no connection to  path u:\.
best regards
Message 8 of 10
(6,075 Views)
the problem is solved. It was the USB stick itself. I tried another one and it worked.
Thanks for your help, i learned something new 🙂
Message 9 of 10
(6,067 Views)
oh man, we could have spend weeks here, trying to figure out whats wrong, without considering that, lol
great you checked that!
until next time
Message 10 of 10
(6,062 Views)
