cRIO 9053 Analog Threshold Triggering
Hi guys,
I have to develop an acquisition system using my cRIO 9053 (enabled to use NI DAQMX) which has to start the acquisition of all sensors in a synchronized way when one of it (let's call it the master) senses a value above a threshold (positive or negative). If possible i would like to get also pretriggered samples.  In addition it has to stop the acquisition when the master sensor output value is in a certain range.
Can you please give me an advice on how handle this problem? Actually i have already set up an acquisition system but i'm starting/stopping the acquisition in a  manual way via TCP.
Thank you in advance 🙂
Have a nice weekend
Antonio
Message 1 of 1
(977 Views)
