cRIO-9053 Send Data TCP
Hello Community:
Actually I have developed a FPGA system that reads 4 channels at 51.2 Ks/S those values I shoudl send through TCP to a TCP server in a Jetson nano programmed with Python.
Actually this is happening I am able to send a string with the values, BUT for sure I am not reaching the sampling that I need, I must sent the 51.2 Ks per channel.
Actually I have developed a producer-consumer script. The producer reads the 4 channels and transform the values in strings and put in a FIFO that is cosumed by the second part.
The cosumer also send that info using TCP write module.
But I thing the TCP can not handle the speed of the loop.
Anyone knows a better aproach.?
Message 1 of 1
(1,291 Views)
