cRIO-9053 application
Hi All,
I would like to ask for a help with the following issue. I created a project with cRIO-9053 containing NI-9239 module. NI-9239 has FPGA programmed, which is being used by RT VI. RT VI is launched dynamically through Run VI method from main VI on host PC. It works just fine when being launched from main VI. I would like to create application from the whole project, however, I cannot include RT VI in my build, thus preventing me from dynamically launching it in application. Is it actually possible to make it work this way, or do i have to somehow redesign the whole thing to make it work as application?
(2,196 Views)
The real time VI is deployed to the cRIO, so you only need to deploy the main VI for your application.
(2,176 Views)
