cRIO-9055 software install problem in MAX
Government laptop running Windows 10 that is setup so that it cannot access the internet.  LabVIEW 2022Q3 with proper modules/drivers for cRIO installed.  Attempts to install LabVIEW RT fail.  Please read attached Word doc for description.
(780 Views)
When using the offline feed, cRIO will access the packages from https://<local-ip-address>:<port> instead of download.ni.com.
Double-check your steps and make sure you follow the instructions.Installing Software to Offline NI Linux Real-Time Targets
https://tmesystems.net/
(740 Views)
Thanks ZYOng,
All of the off-line feeds installed correctly.  The problem occurs when I am in MAX and right-click Software under the remote target and click Add/Remove Software.  That is when the pop-up appears and I never get a chance to install anything.
Are you implying that I have to use off-line feeds to install anything, including LabVIEW Real-Time?
Roy
(731 Views)
