cRIO-905x, DAQmx, Error -200284
Greetings, I have a very simple setup with a cRIO-9056 and one 9213 thermocouple module.  I am trying to run a simple NI AI continuous read example and am getting error -200284 (Some or all of the samples requested have not yet been acquired.) after running and receiving data for a short while (5-20s).  The cRIO project is setup with the 9213 module in the Real Time Resources Folder.  (It is also configured in Max as a DAQmx module).  I have tried the same experiment with 2 other modules and am seeing the same problem.  I noticed that I can open a test panel in MAX and see continuous AI read data at the same sample rate (100s/s).  I presume that MAX uses the same DAQmx/RIO dll so it appears the drivers (v18.5) and HW are working.  I have tried running the AI example with various settings such as 100S/s, 100S or 100S/s and -1 samples to acquire and still no luck.  I have attached a MAX report of my setup.
(1,963 Views)
Have you check on this resource?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2ClCAI&l=en-US
(1,935 Views)
