cRIO-9063 boot problem
Hi All,
I have a problem with booting up my cRIO.
Boot up with:
USB connected (default IP 172.22.11.2) works without any problem with or without cable connected
eth cable connected (some IP) works without any problem with or without cable connected
TP-Link Wireless N Nano Router is connected to eth0 port. Router is set to access point. So, it enables my app to connect to the cRIO using wifi.
When the router is not connected to the eth0 port, cRIO boot up without any problem, application starts, router is connected and app and cRIO is operational.
When the router is connected, cRIO won't boot up. It keeps restarting.
I managed to get the log of what is happening since start of the cRIO booting. Log is attached.
Is there anyone who experienced something similar or knows how to solve it?
Please read the file with the Notepad++ or similar editor. Regular Notepad does not display the logs in pretty way.
Duri
(2,736 Views)
Do you have "Halt on IP Faliure" turned on in NI MAX?
The small TP link Nano routers when configured as Access points rely on the original WiFi network to do the DCHP server (Assign out IP addresses) This is often blocked by some corporate WiFi networks as most block the ability for IP address pass though.
Certified LabVIEW Architect, Certified Professional Instructor
CLA CPI
(2,449 Views)
