cRIO 9066
Hello guys
I have two benches each one with it's own cRIO and HMI. Now i need to connect the two benches to a embroidery frame with more two cRIO and a PC that will receive all data and control the two benches. How can i connect the cRIO from the benches to the embroidery frame cRIOS? It is possible to acquire data from the two benches at the same time?
Thank's a lot
(4,506 Views)
For your cRIO connexion you can put them on the network together by linking them via Network switch or a router.
By the way, you can connect and make acquisition (synchronous or asynchronous) with much cRIO that you want.
Alexis
(4,457 Views)
