cRIO-9074 CAN communication
I am currently running my cRIO-9074 in FPGA mode for measuring vibration, temperature and voltage data using C Series modules. The data is then sent to a host PC through DMA, and the system has been working time for some time.
I now need to also communicate with CAN sensors, and for that I am trying to add a NI-9862 module to the system. However, when I try to add the module to the FPGA target in the LabVIEW project, I get the following message:
"This C series module is not supported by the current versions of LabVIEW and NI-RIO."
From what I read here, the minimum requirements for the NI-9862 is supported by LabVIEW "2010 SP1 to Current", and "NI RIO 4.0 to 14.5; NI CompactRIO 15.0 to Current". Since I am running LabVIEW 2019 f2 + NI CompactRIO 2024 Q1 on my host PC, and "NI CompactRIO 19.6 - December 2019" in the cRIO-9074, shouldn't the NI-9862 be supported? Is there some additional software that I need to install in order to set up the module?
Thanks in advance,
Message 1 of 11
(1,354 Views)
Do you have the NI-XNET driver ?
You may have already looked at this, but if not the following page for compatibility for the NI-9862
https://www.ni.com/en/support/documentation/compatibility/09/software-support-for-compactrio--compac...
then in the notes it mentions some compatibility things to check under "notes"
Consultant Control Engineer
www-isc-ltd.com
Message 2 of 11
(1,330 Views)
See Getting Started with CompactRIO - NI-XNET Manual
https://tmesystems.net/
Message 3 of 11
(1,310 Views)
Thanks for the answers!
I did not had the NI-XNET driver, but I installed version 19.6 today, following the steps suggested by ZYong. After installing it in both the cRIO and host PC, I got different error messages:
  • When trying to add the module in the FPGA target: "This module is not supported in FPGA Interface programming mode. To use this module in Scan Interface programming mode, discover the module from the Real-Time Scan Resources item in the LabVIEW project"
  • When trying to add the module in Real-Time Scan Resources: "This module is not supported in Scan Interface programming mode on this target."
Is this still a missing package problem?
Message 4 of 11
(1,250 Views)
NI-986x is not added under FPGA nor Real-Time Scan Resource.
Right-click the chassis item under the controller (not FPGA) and select New»C Series Modules»Existing target or device
See NI compactRIO target section of Getting Started with NI-XNET Installing and Configuring It for NI VeriStand and NI LabVIEW
Message 5 of 11
(1,243 Views)
I tried following these steps, but unfortunately there is no C Series Modules under the New section of the Chassis. The only thing that shows in the menu is the FPGA Target, which is greyed out since it is already in the project:
Do I also need Veristand for it to work?
Message 6 of 11
(1,234 Views)
No, you don't need VeriStand. I shared that link because it has some images for better illustration.
Ideally, your host PC and RT target should have the same driver version. Besides, according to NI Hardware and Software Operating System Compatibility, cRIO-9074 is last supported in NI-cRIO 19.6. Hence you should uninstall NI compactRIO 2024 Q1 and install version 19.6
Message 7 of 11
(1,227 Views)
@ZYOng  escreveu:
I see, thanks!
@ZYOng  escreveu:
Ok, I did this and I am currently running version 19.6 of all related drivers. Still, there is no option to add C Series Module to the cRIO-9074 chasis.
Message 8 of 11
(1,215 Views)
Can you attach your MAX reports for both host PC and cRIO-9074?
Message 9 of 11
(1,203 Views)
Sorry for the wait, took me some time to get access to the PC again. Here are the reports!
Message 10 of 11
(1,136 Views)
