cRIO-9074 Software Install Problem in MAX
After selecting Software under my cRIO9074 Remote Systems in NI MAX then clicking Add/Remove Software icon, the LabVIEW Real-Time Software Wizard starts. But there is no items to select under the title National Instruments RT Software. And when I select Next, it just states "No items are selected for install or uninstall." Can someone help me with the problem. I have the Safe Mode switch turned on. I have cRIO software/drivers installed.
(1,605 Views)
Accepted by topic author Paul_Belcan
From the screenshots, it looks like you are using recent versions of LabVIEW. The older (VxWorks) cRIO controllers are not supported after LabVIEW 2019. This may be your issue.
This page gives compatibility information for different hardware:
https://www.ni.com/en-us/support/documentation/compatibility/09/software-support-for-compactrio--com...
(1,571 Views)
That fixed the problem.  Thanks!
(1,560 Views)
