cRIO 9076 and problem during FPGA compilation : Error while executing "process run "Synthesize - XST"
I have a cRIO-9076 and tried many times to compile complicated and very simple FPGA files into my cRIO. Each time I am performing compilation process there is a error during compilation - Xiling Error.
Is anybody know what is the problem with my controller how to fix this?
Does it mean that processor is broken?
Please, support me with this case.
Many thanks.
Cezary
Error on compilation status:
Compilation failed due to a Xilinx error.
Details:
ERROR:TclTasksC:process_077: Failed to complete. Please inspect the log and report files.false
    while executing
"process run "Synthesize - XST""
    (file "C:\NIFPGA\jobs\trK3NVz_XI64xG6\synthesize.tcl" line 20)
Message 1 of 8
(6,478 Views)
hello,
i'm having the same problem with cRIO-9075:
Details:ERROR:TclTasksC:process_077: Failed to complete. Please inspect the log and report files.false    while executing"process run "Synthesize - XST""    (file "C:\NIFPGA\jobs\Y3BvnuW_rYTw6YC\synthesize.tcl" line 20)
ERROR:HDLCompiler:806 - "C:\NIFPGA\jobs\Y3BvnuW_rYTw6YC\PkgCommIntConfiguration.vhd" Line 64: Syntax error near ",".ERROR:HDLCompiler:69 - "C:\NIFPGA\jobs\Y3BvnuW_rYTw6YC\PkgCommIntConfiguration.vhd" Line 72: <knumberofdmachannels> is not declared.ERROR:HDLCompiler:854 - "C:\NIFPGA\jobs\Y3BvnuW_rYTw6YC\PkgCommIntConfiguration.vhd" Line 29: Unit <pkgcommintconfiguration> ignored due to previous errors.
i also applied flexRIO patch — http://digital.ni.com/public.nsf/allkb/BBD7A87F2ADC2028862577FB005F6B19, but the problem still exists. seems that the compiler doesn't understand system configuration.
can anyone help me? is this hardware or driver or compiler problem?
thanks in advance.
Message 2 of 8
(6,397 Views)
Hello, I received help from NI. It is necessary to change in Windows regional settings " , " for " . " it means we should write 10.0 not 10,0.
Cezary
Message 4 of 8
(6,391 Views)
Cezary,
unfortunately it doesn't solve the problem in my case.
any other suggestions?
Message 5 of 8
(6,389 Views)
Regardnig to first suggestion. You need to restart windows and make project again!
If it will not help
Try to install new software (I received this suggestion also but never done it because first changes gave positive results)
http://joule.ni.com/nidu/cds/view/p/id/2598/lang/en
Huge file!
Best regardss,
Cezary
Message 6 of 8
(6,381 Views)
Accepted by topic author Cezary
Cezary,
rebuilding the project solved the problem.
thank you very much!
Message 7 of 8
(6,375 Views)
Yes same here had to rebuild thanx for the advise
Welcome here we have some helpful information
Ladies Shoes
Wholesale Shoes
Website Templates
Dropshipping
Message 8 of 8
(6,365 Views)
