cRIO-9215 vs LABVIEW 8.21
hello!
Does anybody knows why the NI cRIO-9215 (with NI USB-9161)  is invisible for LABVIEW 8.21? When I'm trying to acquire some signal using the DAQ Assistant (Acquire signals->Analog input-> voltage) the response is "no supported device found". I installed the NI DAQ, NI DAQmx Base. What is more in the Measurement &Automation Explorer my device can be seen and is OK. But in "Data Neighbourhood" the problem is similar: "no supported device found". What to do?
Message Edited by przemmo on 03-06-2008 09:42 AM
Message 1 of 1
(3,240 Views)
