cRIO Analog output is not continuous for high speed sampling
Ok, thanks for the advise!
It is a sine that is sampled 400 times in one period, so if I want to have a sine with a period of 1 kHz I need a sampling frequency of 400kHz. As the clock of the compactRIO is 40 MHz, AO Rate (ticks) is 40 MHz/400kHz= 100 ticks.
Message 21 of 24
(1,402 Views)
The max rate for your card updating just one channel at a time is 3us (pg 14) = 120 ticks minimum.
I reworked your FPGA code a bit to show the pipelining, add some debug, clean some stuff, etc
Message 22 of 24
(1,398 Views)
Hi Nanocyte
Thank you for your extensive help the past days. I learned a lot in a short time frame about FPGA and buffers. And I think a lot of people who are struggling with FPGA speed and timing will find a lot of solutions on this forum. As conclusion, if I go to a sine of 300 samples I will be able to generate my 1kHz sine. 😉
Regards
Jasper
Message 23 of 24
(1,389 Views)
One additional small note on the pipelining:
Normally you would have an additional data valid flag as well. On the first time around your loop there is no valid value for the output phase so it will probably write zero. In this case, it is probably not noticeable anyway (as the module starts at 0V) but a good reference note for the future.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
Message 24 of 24
(1,384 Views)
