cRIO Application crashes unexpectedly after less that 3hours running
Hey guys,
I have an RT application working on cRIO 9063 to acquire 3phase voltage and current signals of a load.
When testing the system with a computer (via ethernet cable) the acquisition works fine. But when I run the application at startup of the cRIO, I noticed after a while that the system is not working anymore.
The highlighted line is the noticed problemThe highlighted line is the noticed problem
 The RT error log along side the relative VIs (the main VI is 3UI-v RT.vi, subVIs couldn't be uploaded all here) are attached to this thread.
What do you think the problem is?
(2,512 Views)
Hi REaymane,
I suggest looking at this knowledgebase article:
Error 1633 LabVIEW Real-Time Process Encountered an Error and Restarted Automatically
The issue could be with the drivers.
(2,488 Views)
