cRIO NI 9068 UDP Communication Windows Touchscreen computer.
I have a Windows 10 HMI computer running as an overall control computer for 5 cRIO 9068s, In trying to set up communications between the cRIOs and the HMI, I made the sub VIs used in the attached VIs. Everything works just fine until I build the cRIO portion of the code and send it to one of the 9068s. Once running as the startup program, The UDP Receive portion of the VI executes and receives data from the cRIO, but the UDP Transmit will then sit and act as though there is no response from the cRIO. If there are any suggestions, I would appreciate it. I'm certain I'm leaving out details that are important. Please ask if more is needed.
Message 1 of 1
(1,648 Views)
