cRIO Scan mode
I am new using cRIO and I need do make data acquisition of thermocouples using a cRIO. I only need to "pass" the temperature of the thermocouples from the cRIO to my Labview program. I was told to use Scan mode and shared variables. I've created a Labview Real Time project and added my cRIO and modules on the project explorer. I already have my program that will run on windows. But now, I don't know where to put my VI (to the windows) on my project. Also, I don't know how to "pass" the variables from the cRIO to my program. Can you help me? I also wanted to know how can I simulate a cRIO to test it.
Thanks.
Message 1 of 8
(6,528 Views)
I'm just going to reiterate what I told you in another thread:  Go and start reading the NI LabVIEW for CompactRIO Developer's Guide.
Furthermore, you might want to check out the free (if you have a current SSP) online training.  I'm pretty sure Real-Time 1 is in there. (Self Paced training beginner to advanced, SSP Required)
Message 2 of 8
(6,527 Views)
Sorry to bother, but I really need to solve this soon, I don't have the time to read all the tutorial. I thought that it was a simple task and that somebody coul'd walk me through it.
Message 3 of 8
(6,519 Views)
Ok, let's go through the quick and dirty.
You Windows applications go under the My Computer of your project.
The super simple way to pass your thermocouple data is to go into your Scan Engine variables and make them Network Published.
Message 4 of 8
(6,515 Views)
Thank you, I'll try it.
Message 5 of 8
(6,513 Views)
If I only do what is in my vis right now with the crio plugged in it will work? I can't simulate 😞
Message 6 of 8
(6,494 Views)
You really should zip up your entire project (including the project file) and post that zip file.  There is too much missing from the project file to see if things are correct.
Message 7 of 8
(6,470 Views)
Crossrulz,
Thank you very much for the link to the developers guide.
That one post answered at least 50 questions I had.
David
Message 8 of 8
(6,419 Views)
