cRIO Usermanagement used in own webpage on cRIO
The webserver functionality is awesome. By now you can create awsome webpages on the cRIO.
Normally you want to introduce userlevels to a webpage. e.g. some people may change variables some may only view them.
Therefore you have to introduce a user management, which can be done by cockies and java script. But there is a user management on the crio.  Is it possible to reuse the crio user management in an custom webpage build on the cRIO?
It should be possible by using java script, isn't it?
I have no root, I have a superuser!
Message 1 of 1
(2,484 Views)
