cRIO deployment failed
I am working with FPGA cRIO 9075 and three 9402 LVTTL modules. I would like to run a Web Service from my Real-Time target. For test purposes I created a simple calculator that should add two values and return the sum. This was done according to the document: https://www.ni.com/docs/en-US/bundle/labview/page/tutorial-creating-and-publishing-a-labview-web-ser.... At first I run the web service on localhost and it worked without problems. Next, according to the document: http://digital.ni.com/public.nsf/allkb/38228A35DCBA2591862576480059B388?OpenDocument. I created RESTful web service on Real-Time target. However, after using Deploy I see following error:
The Print screen is in German language but it can be translated into: “deployment failed”.
I also tried to deploy the Web Service manually (https://www.ni.com/en/support/documentation/supplemental/08/labview-web-services-faq.htm) but it also does not help. After I reboot cRIO the Web Service web page cannot be found.
I am working with LabVIEW 2011, NI-RIO 4.1, FPGA and Real-time modules. On cRIO I have installed following software:
Am I missing software component/components? What causes the described the problem?
Thanks in advance!
Chris
(5,477 Views)
Hello Chris
please install this option on your cRIO system
In the project now you can launch and configure the web server
I hope this helps, if not please let me know
SRQ 1244864
best regards
Alexander
(5,455 Views)
