cRIO freezing when running remote front panel
Hi there,
I am currently experiencing a problem which is a bit strange.
I have an RT application which is sending data via TCP via port 30000, the datarate is about 1 MBit per second.
For remote access I have a web gui running on port 8000 on the same system.
The problem is as follows:
When I first start the connection for the data transfer and then open the webgui, the cRIO freezes and stops execution.
When I first open the webserver and after that the data connection, then it works but if I make a refresh of the webpage, the system freezes again.
In the RT logs I found the following entry:
#Date: WED, MAY 05, 2010 10:34:58 AM
#OSName:
#OSVers: 6.3
#OSBuild:
#AppName: /c/ni-rt/system/lvrt.out
#Version: 10.0.1
#AppKind: AppLib
05/04/11 08:39:19.562 AM
source/server/TCPServerPacket.cpp(255) : DWarnInternal: TCPPacketInflateHelper::ReadLong: ofst(0)+4 > size(0)
The behaviour is occuring on two systems in the exact same way, my setup is (for both units):
cRIO 9025 with LV2010 and RIO 3.6
The system load is 20 to 50 %, with 20 % Ram used.
Has ever someone else seen a behaviour like this? Any help would be very appreciated.
Yours sincerely
Philipp Nörtersheuser
(3,801 Views)
Hi Philipp,
just a question, what do you mean with "the cRIO freezes and stops execution"?
Are you loosing the connection to the cRIO or does the VI or rtexe stop executing?
Kind regards
Carsten
(3,796 Views)
Hi Carsten,
the cRIO stoppen its RT exe or VI and was also no longer responsive to any ethernet connection (Project, Browser, Port or DSM).
But I already found a solution to the problem, by reaplcing the timed loop, in which I sended the TCP data, with a normal while loop. That fixed it, eve though I do not understand why, but it works now...
Cheers Phil
(3,793 Views)
Hi Phil,
glad to hear the the code is running now.
Don't know why switching to a "normal" loop fixed the problem but keep in mind that a timed loop is always running in a single thread.
So maybe you are using code inside the loop which can be parallelized now
Kind regards
Carsten
(3,790 Views)
