cRIO freezing when running remote front panel
Hi there,
I am currently experiencing a problem which is a bit strange.
I have an RT application which is sending data via TCP via port 30000, the datarate is about 1 MBit per second.
For remote access I have a web gui running on port 8000 on the same system.
The problem is as follows:
When I first start the connection for the data transfer and then open the webgui, the cRIO freezes and stops execution.
When I first open the webserver and after that the data connection, then it works but if I make a refresh of the webpage, the system freezes again.
In the RT logs I found the following entry:
#Date: WED, MAY 05, 2010 10:34:58 AM
#OSName:
#OSVers: 6.3
#OSBuild:
#AppName: /c/ni-rt/system/lvrt.out
#Version: 10.0.1
#AppKind: AppLib
05/04/11 08:39:19.562 AM
source/server/TCPServerPacket.cpp(255) : DWarnInternal: TCPPacketInflateHelper::ReadLong: ofst(0)+4 > size(0)
The behaviour is occuring on two systems in the exact same way, my setup is (for both units):
cRIO 9025 with LV2010 and RIO 3.6
The system load is 20 to 50 %, with 20 % Ram used.
Has ever someone else seen a behaviour like this? Any help would be very appreciated.
Yours sincerely
Philipp Nörtersheuser
Message 1 of 1
(3,599 Views)
