cRIO not showing up in MAX, but it responded to a PING
The Power, LINK/ACTIVE, and 10/100 LEDs are lit on the cRIO. The cRIO is plugged into my NI Chassis via a crossover cable. I started up MAX and nothing appeared under Remote systems. I tried refreshing and nothing showed up. I successfully pinged the cRIO. MAX still does not list in under Remote Systems and when I try to add it in (right click on remote systems>create new) I select Remote VISA device and enter the IP of the cRIO it says it already exists as a MAX remote system, and to configure it, go to the VISA options>remote page. I did this and it gives me the same response. My cRIO and Chassis are on the same subnet, and obviously they can communicate with each other.
I have LV 8.2, NI Vision and the FPGA module installed.
Please help, as I have a deadline on this wednesday.
Thanks in Advance,
Jack Minardi
(3,448 Views)
It turned out I did not have NI RIO installed. I was told that it was included with the FPGA module. Oh well, atleast I have it installed and working now.
(3,434 Views)
