cRIO serial communication
Hello to everyone! I have a question abouth cRIO 9074, I am completely new with it. If I want to make serial (RS232) communication between cRIO and my PC do I need to use LabView for a graphical interface or i can make a C# app which will communicate with the controller?
(3,451 Views)
You will need to use LabVIEW RT on the cRIO side.  On the PC side, it does not matter as long as you follow the same protocol.
(3,443 Views)
http://www.tldp.org/HOWTO/Serial-Programming-HOWTO/
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
(2,714 Views)
