cRIO system no longer works with new NI-9514
Dear NI,
For a while now, I have been running a Compact RIO system with a NI-9022 controller and a NI-9116 chassis with 7 NI-9514 motion modules. In order to overcome the limit of 4 motion modules, I was advised to use a workaround whereby the system would operate in "hybrid mode", but all of the motion modules would actually operate in scan engine.
In order to do this the first time, I had to run a blank VI on the FPGA, run this, switch scan engine to active mode, and then deploy all of the axis. On subsequent occasions, I could just run a VI which references and dereferences the FPGA and then switches scan engine to active mode programatically (this VI is attached). This would then enable all of the axis and allow me to use SoftMotion to control all 7 axes.
Recently, I have added another axis and another NI-9514 module, and have repeated the above setup. When I run the blank VI on the FPGA and then manually switch scan engine to active mode, all of the modules are enabled and I can run motion programs. However, If I use the VI to do this programatically, the "Switch scan engine mode" VI returns and error:
Code: -77072
Possible reason(s):
NI SoftMotion: Communication to the hardware device exceeds the timeout limit.
It is worth noting that, even with the new axis fitted in the chassis, as long as I don't add it to the project, I can still run my project as normal.
Are you able to advise on how I can solve this problem?
All the best,
James Polyblank
PhD Student
(5,834 Views)
Accepted by topic author JamesPoly
Hello all,
I managed to resolve the problem - The "FPGA Open Reference" VI was pointing to an out-of-date bitfile, so recompiling was making no difference.
All the best,
(5,807 Views)
