cRio 9056 can not install NI Compact 20.5
Hello
I have the problem that when I want to install NI Compact 20.5 as companyware via NI MAX on the cRio 9056 I always get the error message at the installation step NI FSL Components.
I have installed the same version on a cRio 9035 with no problems. Tried it with an 18.5 version which has the same problem in exactly the same place.
My 2nd try was to install it over the new Linux system image. Here NI-Max unfortunately does not manage to start the NI web server and the required feeds are not accessible.
Has anyone had the same problem and found a solution for it?
With kind regards
Sebastian
Message 1 of 1
(962 Views)
