cRio-905x Ethernet over USB Gone after RT sw Installed
How to recreate the issue:
1. Have the latest cRio-905x model
2. Factory reset, format the whole device.
3. Have a PC without firewall, all admin access with all the (latest 2021) NI software and drivers, since I use LV 2021 SP1.
4. Connect the cRio-905x to PC using USB cable.
5. Make sure device is connected, with IP 172.22.11.2 ping success.
6. Connection established on NI MAX, discovered and install the RT into the target device.
Right after target device complete RT installation, the eth over USB connection will no longer work:
The following error will appear: Showing target device fail to restart.
Now the device will no longer able to connect through USB.
I need to use USB to connection to my main control host PC.
Any solution out there?
I've consulted NI technical support, so far, their recommendations I've tried are all not working:
Sites recommended by the NI Tech Support that are not helpful to my situation:
CompactRIO Ethernet over USB Connection Known Issues - NI
Can't Find RIO Connected via USB in NI-MAX - NI
Installing Software on the Controller - NI
How to Fix a cRIO That Only Starts in the Safe Mode?
Message 1 of 1
(607 Views)
