cRio data acquisition problem
I need help with my data acquisition using fpga cRio 9072. I am relatively new to labview and i started with "NI 9323 Getting Started" vi and i managed to acquire data from my 9232 module, using fpga. The problem is that when i try to plot the data, on the OY axis i have voltage ( and this is ok) but on OX axis i have the sample number, instead of time. My data is like in [1] and i would like it to be similar to the one in [2]. I do not want to have on the ox axis the absolute time (time and date) but more of a relative time that resets to 0 each time the acquisition starts.
I would appreciate your help,
Valetina
(5,780 Views)
can you attach the fpga vi code where you read the data and also the RT vi code where you display the data on graph. i want to ask some questions as follows;
1    do you used FIFO to transfer data between target (fpga) and host (RT) ?
2    do you used waveform generation vi (its attributes are Y , dt and t0) ?
(5,688 Views)
Hello Tirmizi
I managed to solve that problem. Your tip nr. 2 was of great value, thx a lot!
I now have another problem that i deal with for a long time. I posted it here: http://forums.ni.com/t5/Real-Time-Measurement-and/cRio-FPGA-read-1024000-samples-and-transfer-to-RT/...   I would appreciate if anyone could help...
(5,496 Views)
