can I see the LV code from a saved file obtained with replication system
I have obtained an image of a C-Rio using Replication system.
I would like to see the code from it,
is it possible to see the code?
(3,130 Views)
When you replicate a cRIO Real-Time system, there is no source code infomation stored in the image.
However if your org. cRIO target contains source codes in it's storage, then they will be imaged as well and you will be able to access the VI's after the restoring process.
More about "Real-Time Target System Replication"
http://zone.ni.com/devzone/cda/tut/p/id/3937
Hope this helps.
Dennis Morini
District Sales Manager
National Instruments Denmark
http://www.ni.com/ask
(3,107 Views)
