choose adc range in 9642
(3,059 Views)
Though I cannot be sure based on the detail of your question, but I assume you are looking to define the nominal input range for Analog channles sampled using the integrated 9205 C-Series module?
In the LabVIEW project explorer, integrated modules will be enumerated as part of the FPGA target. You may rick-click the 9205 AI module, and select 'Properties.' The Properties dialog box will allow you to select the nominal input range for each of the sampled AI channels.
Please post, if this is not the intent of your question.
Cheers,
Patrick Corcoran
Application Engineering Specialist | Control
(3,035 Views)
