communication error occured when starting/stopping VI
Hi all,
I am having a frustrating situation.  I am trying to run some VIs on a Compact RIO 9073 chassis, and every time I start or stop the VI, I get two popups: "Communication Error Occured" (spelling is as on the popup) followed by "Warning: Connection to the Real-Time target (NI-cRIO9073 blah blah) has been lost".
If I then go into the project manager, right-click on the cRIO and select Connect, it reconnects fine, and the VI is still running.  I then get the same two popups again when the VI stops.  In the meantime I can communicate with the VI with no issues.  I've tried reinstalling the software on the RIO to the NI-RIO 3.4.0 Minimal, but it hasn't helped.
On the RIO I have LabVIEW Real-time 9.0.1, NI-RIO 3.4.0, and NI-VISA and Visa server 4.6.  Same numbers on the computer except that Real Time is 9.0.0.
Any suggestions would be greatly appreciated!
Cheers,
~Ben
(3,446 Views)
Accepted by topic author benloer
::sigh::
Never mind,  I noticed it myself when I realized that my RT versions were different.  (Seems the naming scheme might need a bit of tweaking if .0.1 is different enough to break things...).
Not sure how I managed to get a newer version of RT on the box than on the pc, but oh well.
(3,444 Views)
