03-05-2007 04:10 PM
03-07-2007
04:27 PM
- last edited on
10-24-2025
04:19 PM
by
Content Cleaner
Hi Jaavier1,
In order to do analysis of power quality, you will probably need to isolate, filter, and attenuate the signals to measure the voltage and the current. This can be done various ways. You can use an ammeter to lower the current to a level that you can measure using the cRIO or use some other type of current sensor. The voltage attenuation can be done several ways, but you will most likely need a voltage transducer. The maximum input range for a cRIO analog input module is +/- 60 V and +/- 20 mA. Some sensor recommendations are made in the following forum:
https://forums.ni.com/t5/Real-Time-Measurement-and/High-voltage/m-p/337762?requireLogin=False
For more information on power quality measurements, you can take a look at:
http://zone.ni.com/devzone/cda/tut/p/id/3059
http://zone.ni.com/devzone/cda/tut/p/id/4714
Hope this helps.
Saludos,
Erin
NI Mexico
03-08-2007 05:47 AM - edited 03-08-2007 05:47 AM
Hi, I worked on something similar in my undergrad. I attach a summary which probably explains what you are asking for.
Hope this helps.
Mohd
Message Edited by Moh on 03-08-2007 01:47 PM
03-08-2007 08:47 AM
03-08-2007 08:50 AM
03-08-2007 08:50 AM
