‎06-16-2020 07:24 PM - edited ‎06-16-2020 07:29 PM
I am new to sbRIO system, and not very familiar with the system, as well as VHDL. I have a very fundamental question about how to use I/O node of sbRIO in Labview. I dragged the port, but unlike cRIO, I could configure nothing. (show in image). I think I should define the direction and so other parameters before I can use the I/O port, but simply do not know how.
Could somebody give me some hint or very fundamental level step-to-step instruction?
I used to work with Altera FPGA, and configure the pins in Quartus. Is there anything similar in Labview?
Really appreciate.
Solved! Go to Solution.
‎06-16-2020 10:20 PM
Issue solved. 🙂 The VI file should be under "Target", but I put it under "Chassis".
