I wonder if anybody has previous experience in connecting to a cRIO via a small form factor (SFP) fibre transceiver Small form-factor pluggable transceiver - Wikipedia
Essentially, the cRIO is in a high-voltage area and not allowed to pass a copper ethernet cable through the boundary. so I have to convert that to fibre optic. I can either use a media converter or this fancy SFP module.
please let me know if that works just plug an d play or if I should have more set up done to get that to work.
thanks in advance
