crio 9022 does not boot anymore
my cRIO 9022 does not boot anymore and on the consol, I see that the boot stops after the message
Starting at 0x10000...
I have the following message:
In safe mode :
cRIO-9022 Boot
Copyright 2008-2009 National Instruments Corporation
Bootrom version: 2.1.2f2
Creation date: Jan 7 2010, 16:07:25
Press any key to stop auto-boot...
0
auto-booting...
Booting into Safe Mode from ROM...
Uncompressing kernel...done.
3752544
in normal mode
cRIO-9022 Boot
0
auto-booting...
boot device : usbms
unit number : 0
processor number : 0
host name : lvrt
file name : /c/ni-rt/system/vxWorks
flags (f) : 0x8
Attaching to USB disk device...
USB mass storage firmware version: 1.0.0f2
Using SST NANDrive
Reliance File System Driver
Datalight Reliance v3.2.2 Build 1376BV
VxWorks Edition for ppc603
Copyright (c) 2003-2008 Datalight, Inc. All Rights Reserved Worldwide.
Loading /c/ni-rt/system/vxWorks...2888096
(1,189 Views)
The USB drive may have a problem- remove it and see if it boots normally. If there is an issue with the USB drive, try swapping it out for another one. You will want to make sure that it isn't too big and that it is formatted properly- it needs to be FAT16 or 32.
If you can connect to the device in MAX under "remote systems", right click and format it. This will remove all software, but you can keep the network configuration. After the device is formatted, reinstall the software. If the status LED continuously blinks, or is solid, then there may be a hardware problem.
cRIO-9022 User Manual and Specifications
Hope this is helpful!
(1,120 Views)
Hi ,
thank you for your reply; Currently I only boot from internal memory.
I don't have a USB key with a vxworks boot; and for the MPC8347 processor that equips the cRIO9022;
I tried all the flags to boot but without success.
[cRIO-9022 Boot]: ?
? - print this list
@ - boot (load and go)
p - print boot params
c - change boot params
l - load boot file
g adrs - go to adrs
d adrs[,n] - display memory
m adrs - modify memory
f adrs, nbytes, value - fill memory
t adrs, adrs, nbytes - copy memory
r - reset boot line to default
s - boot to safe mode from ROM
u - boot from USB
T iterations, mode - test memory
R - show results of last memory test
e - print fatal exception
v - print boot logo with version
n netif - print network interface device address
$dev(0,procnum)host:/file h=# e=# b=# g=# u=usr [pw=passwd] f=#
tn=targetname s=script o=other
boot device: usbms file name: /bd0/vxWorks
Boot flags:
0x02 - load local system symbols
0x04 - don't autoboot
0x08 - quick autoboot (no countdown)
0x20 - disable login security
0x40 - use dhcp to get boot parameters
Other flags:
0x1000 - disable vx_exec autoboot
0x4000 - enable USB autoboot
available boot devices:
Enhanced Network Devices
mottsec0 mottsec1 usbms
I als tried to boot with the "u" option but without success because I don't have a vxworks binary on a usb key
 I also tried to boot with the "u" option but without success because I don't have a vxworks binary on a usb key
[cRIO-9022 Boot]: e
machine check
Exception next instruction address: 0x000101e4
Machine Status Register: 0x00041000
Condition Register: 0x24000482
Task: 0 "(null)"
[cRIO-9022 Boot]: r
The Safe Mode DIP switch must be on to alter the boot ROM flash contents
NOTE: Bootline not saved to NVRAM
[cRIO-9022 Boot]: r
Boot line restored to factory default.
[cRIO-9022 Boot]: p
boot device : usbms
unit number : 0
host name : lvrt
flags (f) : 0x8
[cRIO-9022 Boot]: u
Using SST NANDrive
USB disk /u not detected after 5 seconds
Bus 0
Hub with 2 ports at address 1 on port 0
Vendor: 0x0000
Product: 0x0000
BCD: 0x0000
Class: 0x09
Subclass: 0x00
Protocol: 0x00
Hub with 2 ports at address 2 on port 0
Vendor: 0x0424
Product: 0x2512
BCD: 0x0000
Class: 0x09
Subclass: 0x00
Protocol: 0x00
Device at address 3 on port 0
Vendor: 0x3923
Product: 0x73D2
BCD: 0x0100
Class: 0x08
Subclass: 0x06
Protocol: 0x50
Hub with 2 ports at address 4 on port 1
Vendor: 0x0424
Product: 0x2512
BCD: 0x0000
Class: 0x09
Subclass: 0x00
Protocol: 0x00
Device at address 5 on port 0
Vendor: 0x058F
Product: 0x6387
BCD: 0x0104
Class: 0x08
Subclass: 0x06
Protocol: 0x50
No device on port 1
No device on port 1
Loading /u/ni-rt/system/vxWorks...
Cannot open "/u/ni-rt/system/vxWorks".
(1,078 Views)
