crio 9076 inconsistent ip setting
good day
I has problem with connection to the compact RIO
used NI 9076
it appear NI9076 in MAX
also the memory appear
but at system state show "inconsistent IP adress"
so, when I want to create realtime project,
show that at the labview, when go to the target and devices,
"unconfigure IP adress"
at the existing target and devices, nothing appear at the compactRIO chasis.
I already turn off the firewall.
so, how can I fix and solve this problem
can anybody give solution with the step to do.
thank you
MSyadiq
(6,574 Views)
Hello MSyafiq,
1.- is your cRIO conected to the LAN?
2.- are you planning to use cRIO connected direct to your computer?
In the option 1, the cRIO must be in DHCP or Link Local option. You can configure it in Network Settings in MAX. In the option 2, you have to have both developer computer and cRIO in the same net, I mean, dev computer: 169.254.66.10 and cRIO: 169.254.66.100 (this is an example). Firts check the IP address of your dev computer (if you don´t know how to this, click in this link ) and then change to Static option in Network Settings in MAX.
Try with this link. Bye !
Patricio Cortes | NI Cono Sur
(6,402 Views)
