data acquisition card
Dear, I am looking for NI hardware.
I need a data acquisition card that can be used for a weather station.
The station can be located in a remote place (without electric power) therefore, the data acquisition card has to have a low consumption.
I would also like it to be able to be programmed with Labview. If you know of any such card from NI, please pass me the model. Thank you
(1,198 Views)
What signals are you trying to read?  What voltage levels?  What rate?
(1,171 Views)
Thanks Crossrulz for the reply.
I need the board to have 5 digital inputs / outputs and 5 analog inputs.
With 8 bits of resolution it is sufficient.
I also need it to be able to send data over the internet.
It is also necessary that the program can be installed and running on the board without having to be connected to a computer.
Any other queries, please let me know.
Thank you
(1,160 Views)
Based on what you are after, I would probably look at using an Arduino or a RaspberryPi.  You could use the new Linx toolkit from NI to program a Raspberry Pi with LabVIEW.
(1,158 Views)
