data acquisition
which type of daq device should i use if i want to monitor temperature with a thermocouple and the scb-68 pin board?
(3,263 Views)
Generally thermocouple measurements would require relatively high precision (mV range signals), and do not require a particularly fast sampling rate. We typically do not recommend using a DAQ board alone for thermocouple measurements, as the readings are more accurate if some additional gain is applied to the signal before it comes into the board. SCXI or other signal conditioning methods are good for this. However, if you absolutely must use a DAQ board alone, the PCI-MIO-16XE-50 would be a good starting point. To compare with some of our other products, try our online product advisor at http://www.ni.com/advisor/
One additional note, this question is not related to our "real-time" data acquisition hardware, and future questions like this can be directed to th
e general data acquisition category.
(3,263 Views)
